6 | |
5 | |
3 | |
2 | |
2 |
The "control + drag" to create space in a block diagram is a cool feature but sometimes we just can't use it because it would mess up too much the VI.
Most the time, an option to restrict the create space to the structure in which we do the "control + drag" would solve this issue and thus make the create space function more usefull.
Maybe "ctrl + shift + drag" would do the job, I'm open to suggestions 😛
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
