| User | Kudos |
| 12 | |
| 11 | |
| 9 | |
| 8 | |
| 5 |
Many times I like to keep my memory footprint small by using "right-size" data representations for my arrays. Unfortunately, in the event I need to sum the array elements using the 'Add Array Elements' I am stuck in rollover city. I can then blow up the data to a larger size or write out the sum (or product) longhand.
I would prefer an output configuration to let me specify the representation of the array sum or product:
