5 | |
5 | |
2 | |
2 | |
2 |
By default, overrides of interface methods with the default dynamic dispatch connector pane (object in/out and error in/out) look like this:
This means that the default override of interface methods do nothing EXCEPT DROP INCOMING ERRORS, which is bug territory imo. Ideally, they would be scripted to look something like this:
Yes, I know I probably can mess with the project provider to get this. No, I don't want to have to do that! 🙂
