rgvdh@rdf
PID Setpoint Profile VI (PID Toolkit) add error checking
Status: Declined
The "profile" that this VI takes as an input is an array of time/value pairs.  Two sequential points with the same time make a step, two sequential points with increasing time make a ramp or soak.
Currently, two sequential points with decreasing time cause unpredictable behavior.  I suggest they should cause the VI to throw an error instead.
3 Comments
AristosQueue (NI)
NI Employee (retired)
I strongly suspect that not doing this check is deliberate. There is a constant tension in API design, particularly with math APIs, between performance vs. input checking. If I'm writing an algorithm where I know my inputs are good, I do not want the APIs that I call to waste time checking the inputs. This would be such a case.
rgvdh@rdf
>"I strongly suspect that not doing this check is deliberate."
In that case maybe write a "sanity check" or "coerce to sanity" vi?
At the very least, reword the documentation a bit:
"time (s) specifies the time values in the setpoint profile. Specify the time (s) values in ascending order."
"ascending" should be "non descending" as you can have equal times for a step function.
Append "Descending times will result in unpredictable behavior."
Darren
Proven Zealot
Status changed to: Declined
