6 | |
5 | |
2 | |
2 | |
2 |
I was thinking that defining packed project libraries as the source of VIs used by the LabVIEW enviroment would speed up everything ex. loading LabVIEW, loading palettes linking dependencies, building executables etc. + solve linking dependecies conflicts.
The thing that we could do is just add the packed project library for the standard LabVIEW functions as the base of the palettes, but since we want users to be able to see what's inside we would still leave the VIs in the same folders - this way the user would be able to choose if he wants to use the packed versions or the versions from the disk - unpacked.
This way only the ones with a specific unpacked instance would have to be loaded as single VIs, and we would have everything nice and clean.
Tell me what you think.
