8 | |
6 | |
4 | |
3 | |
2 |
I would like to propose the use of a stacked parallel execution structure. Especially in FPGA applications, this will solve the problem of diagrams running off the screen. All execution pages will run simultaneously as if independent while loops were scattered across the BD. This idea potentially leads into a 3 dimensional visuallization of coding LabVIEW. Note: In the image, the pages are offset but should look similar to a stacked sequence structure.
