7 | |
6 | |
2 | |
2 | |
2 |
Subpanel invoknode is not duplicated on block diagram by clicking subpanel on front screen with ctrl+drag
Copy paste of Sub Panel from the front panel by clicking with ctrl+drag is not working as intended. same things happens with ctrl+c & ctrl+v action.
For the two front panel controls(Sub Panel) there should be two function(invoke node) mapped on block diagram. which is not in the case of copy paste of Sub Panel.
We have to manually put Sub Panel from the control pallet, and the name of the Sub Panel is not
auto incremented like other controls like Numeric..Numeric 2, Numeric 3.
Tested on LabVIEW Version 2018.0.0 and 2018.0.1
