LabView could use plugins (like Adobe!) for a lot of the features suggested by those on this forum, instead of implementation only with the latest release. For a lot of university computers that are running on old DAQ boards or simply cycle through their programmers quickly, upgrading to newer versions of LabView isn't an option, both from a price perspective and from a "reprogramming everything" logistics perspective. (I'm in this situation, with a lab using 6.1)
Plugins that I have in mind are:
- Block Diagram Cleanup Utility plugin for versions of LabView before version 8.6. Whatever algorithm the 8.6+ versions use would still work for wires and other objects strewn across the block diagram, so adding this shouldn't be too difficult.
- Zoom functionality for LabView, period. LabView is a graphical programming language, and anything graphical should have some sort of zoom utility. Whether it be to see a large block diagram in its entirety or to zoom in for people with poor eyesight, or simply a graphical readjustment to suit a different sized monitor, zooming is critical to any graphical process. Certainly, LabView wasn't created for artists, but I still think this is very important. Again. Not too difficult to create a plugin that works natively. Failing that, even an NI-supported zoom-in/zoom-out tool that wouldn't allow editing in those zoomed modes would be helpful.
- LabView canceling when opened. I believe I saw this elsewhere in the forum, but basically just something that would allow you to close LabView if it opened accidentally without going to Task Manager. On older machines it takes forever to open. Easy to implement; basically just a GUI change to allow closing earlier.
- An "Open Recent" option. I don't know if later versions have this, but it just allows opening the last project you worked on so much faster than what directory browsing allows. Again easy to implement as a plugin, I'd imagine. Some sort of cache'd memory and a new menu item.
Thank you for your time.
