To better understand the settings in the LabVIEW Options dialog, show popup help when hovering the mouse pointer over a setting.
As of LabVIEW 2012 the user has to open the help and look for the setting in question. Not an issue. Just an idea to help keep NI developers employed. 🙂
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
