don2000
Possibility to choose ENABLED or DISABLED state when diagramm disabled structure is placed on block diagramm
Status: Declined
When pulling the diagramm disabled structure to the block diagramm, it would be quite handy to choose whether it is ENABLED or DISABLED, e.g. by pressing CTRL for ENABLED state.
2 Comments
altenbach
Knight of NI
By default, code is enabled and the only reason to place a diagram disable structure in the first place is the need to temporalily disable some code.  The current default behavior matches that case naturally.
Any other scenario seems very rare and I don't think we should overload the UI with marginal functionality.
Darren
Proven Zealot
Status changed to: Declined
