 shb
			 on
		09-27-2012
		08:51 AM
			2 Comments (2 New)
			shb
			 on
		09-27-2012
		08:51 AM
			2 Comments (2 New)
		Add a button to open a broken VI in the app instance where it would be built.
When a build fails because of a broken VI the application builder shows an error window. Since LabVIEW 12 all the broken VIs are listed inclusive the reason why they are broken. (The list is in the reasons field.) This is much better than before, thanks.
But today I had a list of broken VIs, every single one without a reason. (Example message: broken1.vi: \n broken2.vi: \n broken...)
So I come up with the idea I proposed in this thread (even there were improvements since):
"I ask for a possibility to open the broken VI in the BUILD application instance when this error occurs. This could happen automatically or with a button."
(A general idea about improving app builder: Better error descriptions for Application Builder).
