It's a common convention that the space bar is used to pause/un-pause videos that are playing. It would make sense to me that pressing the space key would toggle the pause button (Pause / Continue).
1) Pressing Space Bar key would be the same as pressing "Pause" on the VI toolbar.
2) Pressing Space Bar key again would "Continue" (un-pause).
