PalanivelThiruvenkadam
Array to Cluster (Double Click Should allow to select Cluster Size)
Status: Completed
Available in LabVIEW 2020 and later. Double-clicking the 'Array to Cluster' function will bring up the 'Cluster Size' dialog box.
Instead of right click on the Array to Cluster for Cluster Size, double click will be ease for the programmer to select the size of cluster
Double click should enable this pop up.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
5 Comments
Technico
An indication of the current value
or a tip strip on mouse over would also be helpful
crossrulz
Knight of NI
Similar ideas:
Change CLUSTER SIZE to a Wired Input
Allow Array to Cluster Type
Array To Cluster Function, add Type to Convert Cluster
(The last two are actually duplicates of each other, just not marked as a duplicate as of the time of this post)
Darren
Proven Zealot
Status changed to: In Development
Darren
Proven Zealot
Status changed to: In Beta
Darren
Proven Zealot
Status changed to: Completed
