I would like to have a mailto hyperlink, so it opens a new draft email from e.g. an about dialog when clicking an email address with "enable hyperlinks" checked.
It could either detect an email address formatting automatically or have to properties be extended with a field to set the actual hyperlink info, like when adding an hyperlink in MS Word.
