| User | Kudos |
| 6 | |
| 3 | |
| 2 | |
| 2 | |
| 1 |
If a DLL is configured in a Call Library Function Node and is either missing or defective, the entire program cannot be executed. In most situations, this behavior is acceptable.
However, it can also be quite frustrating, especially if the part of the program that uses the DLL is not called. Additionally, it would be helpful for debugging purposes if the program could still execute even when a DLL is unavailable.
Therefore, I propose that the configuration dialog of the Call Library Function Node includes an additional checkbox labeled "Break execution if DLL cannot be loaded." If this checkbox is checked (default setting), the behavior will remain as it currently is. If the checkbox is unchecked, the program should run until the affected node is executed. At that point, the node's error output should indicate either "DLL not found" or "DLL found but cannot be loaded," and execution should proceed beyond the node. In this scenario, it will be the programmer's responsibility to handle the error appropriately.
As an extension of this idea, I could also envision a new entry in the LabVIEW.ini / application.ini file to assist with debugging. If this entry is not present, the explicit configuration of the node will be used. If it is available, it will override the explicit configuration with either true or false.
Please also see this related idea: https://forums.ni.com/t5/LabVIEW-Idea-Exchange/get-DLL-path-from-the-call-library-function-node/idi-...
