sandyy
Probe Front Panel :-)
Status: Declined
Probing a Front panel shall be easy to debug.
Thanks All.
Before :
After :
3 Comments
crossrulz
Knight of NI
It's called having the front panel open.  Use a second monitor and move your block diagram to the second monitor and you can look at both your code and your front panel at the same time.
AristosQueue (NI)
NI Employee (retired)
I think crossrulz has the right answer on this one. Is there some reason why opening your front panel while debugging is not an option?
Darren
Proven Zealot
Status changed to: Declined
