| User | Kudos |
| 4 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
The error ring is a handy tool I've just learned about. It would be fantastic to be able to create an error ring for a project that can be type defined to easily distribute with applications. This way all custom error codes for a project may be easily stored with all the project files without having to worry about including a file from the user.lib. Other ring controls/constants/indicators can be type defined, why can't the error ring?
