13 | |
11 | |
3 | |
3 | |
3 |
LabVIEW 2011 allows you to 'Make a Type Def' by right clicking on a control, indicator, or constant. What new users don't realize is that the type definition has to be saved as a custom control. The current save method and prompts are not very clear. Maybe it would be better if the developer is prompted straight after the creation of a type definition to save the .ctl file. This would make it clearer that there is a connection between the type def. and the .ctl file.
