3 | |
3 | |
2 | |
2 | |
1 |
In LabVIEW if I want to use a property/method of a control I have to right click and select property. Same for second control I want to use same property I have to do same operation again. My idea is if we select all the controls and right click, some common property like value, visible and etc..... Should display and by selection it generate automatically. This can reduce my application development time.
So if this key feature is there in LabVIEW we can select multiple controls or properties and perform some basic operations to reduce our application development timing.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
