| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 2 | |
| 2 |
We need the additional properties of the used LabView Editor:
bitness: 32 or 64 bit
ServicePack Number: 1,2,3 ....
Patch Version: f1,f2,f3 .......
So, what i like to have is, that i can get the above listed properties from the currently running LabView Editor, programmatically!
See also forum discussion for the problem:
