sriveni
Text Ring with Case Structure : Display of Item Names in the Case Selector Label
Status: Declined
Hello Team,
When Text Ring is wired to Case Structure, the Case Selector Label displays the Item Values (Numeric) instead of Item Name. It is difficult to keep track of values when we work with large Item Values like error code etc… and also have another issue, if we update the Item Value of an Item in the control, the Case Structure Label does not get automatically updated.
It would be useful we have functionality similar to ‘Enum’  when wired to Case Structure, the Case Selector Label displays the Enum Names  and also automatically updates the Enum Names in the Case Selector Label if the Item Names are updated.
Enum can’t be used in this case because  the Item Values are sequential and can’t give defined values for the Items Names.
In general when the Text Ring is wired to Case Structure:
  1.        The Case Selector Label should use the Item Name instead of Item Value
or
The Subdiagram Label should be automatically displayed with Item Name.
  1.        When the Item Names are changed, the Case Selector Label should get automatically updated with Item Name.
6 Comments
crossrulz
Knight of NI
Here's the problem with rings: They can change at Run Time.  In order to have the string for the case structure, you need something that is set at Edit Time.
So what you really want is this: Add sparse enums to LabVIEW
Therefore, I would call this a duplicate.
Intaris
Proven Zealot
I think he's really only looking for an IDE helper to give a string ID to pre-defined numerical states within the case structure.  That being said, sparse Enums would also solve the problem.
I personally would LOVE the opportunity to label case structure states independently of the input type.
I wanted to link to an idea I had posted ont his idea but now realise that I never DID post that idea.  Hmm, how about the ability to label the cases of a case structure using something else other than the input selector value.  I know on RT casts to enum are ridiculously expensive and that would certainly solve THAT issue.
I'd also like to be able to label cases with Boolean inputs, with U8 Inputs or whatever.  Please bear in mind I'm referring to a purely IDE feature, nothing which would cahnge the compiled code in any way.
jcarmody
Trusted Enthusiast
Perhaps the IDE can display the ring text in the selector label but switch based on the numeric value.  This will allow the text to change at run-time but, if the numeric value is unchanged, the switch will still work.  If the numeric value changes it should default.
Jim
crossrulz
Knight of NI
Intaris wrote: I personally would LOVE the opportunity to label case structure states independently of the input type.
Like the Subdiagram Label?
Intaris
Proven Zealot
Crossrulz, nope, not like the subdiagram label.  I want to be able to see the text when I click on the case selector so that irrespective of the data I'm using to drive the case, I can see the labels for each case.
Darren
Proven Zealot
Status changed to: Declined
