Hi.
If you build the same executable multiple times, the EXE file is always different between each build. (using FC /B on the command-line for comparison)
We have been requested by a customer to prove him he could build the executable himself and get the same executable as the one we built for him.
That's currently impossible.
We opened a service request with one of your engineers and that was the conclusion.
Please provide us a way to compare executables.
Thanks in advance, and best regards.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/LabVIEW-built-applications-should-be-identical/idi-p/1...
