6 | |
6 | |
3 | |
2 | |
2 |
Provide a way to either temporarily (via key press) or permanently (via a LabVIEW option) disable the automatic creation / insertion of shift registers when adding a loop around some existing code. Much like the auto insert feedback node in cycles option.
This feature generally gets it right when dealing with references or error clusters, but other times it'll connect irrelevant data together, requiring extra effort to undo and rewire. The auto-wiring also creates weird bends when connecting the shift registers. When an unwanted shift register is then changed back to a tunnel, the bent wires remain in place.
A typical use case:
