3 | |
3 | |
2 | |
2 | |
1 |
Currently on waveform graph, once a plot is named it cannot be deleted (it can be made blank, but it still shows in all pull downs). For instance I plot 3 graphs, each having 16 plots. I then refresh data and plot only on graph of 11 plots. My new plot names show in the top of the pull downs, but all the previous plot names still show up as well (see attached screen shots).
Please expose a method to remove plot names (property to give array of existing names and property to remove name or all names).
