Provide the possibility that auto generated inputs/outputs are named in english.
The language of the dev environment should not matter.
It should be possible to have a dev environment in whatever language, but still be able to consequently name all front panel/block diagram element in english.
Localizing auto generated elements where one wants to manually name all other elements in english leads to the unbearable situation where languages become mixed up.
It should be taken into account that english is the standard programming language language.
