13 | |
7 | |
3 | |
3 | |
3 |
I would like to see the filename of a type def appear when you choose visible - label. Right now it just shows up blank. I do not want to have to stop to type a unique name
. Adding label to type def
This functionality is already available if you give the control a label within your typedef. See the thread reply from AristosQueue for more information.
