ErnieH
Quick Compile
Status: Declined
Sometimes a quick and easy program is desired by a coworker or to do a test. It would be nice to create or open a vi, modify as needed, and create an exe from the VI itself, and distribute it. Open, edit, compile, send.
Quick compile
  • Ability to open a VI and select compile to exe without creating a project.
  • Use a predefined setup script or a wizard.
  • Ability to decompile from the exe to get the source vi's, if option is desired.
    • The EXE is the source also. No lost code.
  • End user would have a link to download the runtime if not already installed.
1 Comment
Darren
Proven Zealot
Status changed to: Declined
