| User | Kudos |
| 13 | |
| 10 | |
| 7 | |
| 5 | |
| 5 |
Quick Drop (Ctrl+Space) should support replacement (Ctrl+P) on the block diagram terminal as well as the front panel icon. The front panel icon can be selected and replaced with another .lvclass but if its block diagram terminal is selected the replace does nothing.
