6 | |
5 | |
3 | |
2 | |
2 |
First of all - if there's a QuickDrop shortcut or any other feature within LabVIEW that already does what I suggest here, I'll be glad to be pointed the way to it. Thanks.
During testing of programming appoaches I often code a bunch of stuff that should simply work and then break it down later into several SubVIs for better readability, maintainability and reusability. Doing so leaves me with the fact that LabVIEW determines
of controls and indicators of the newly created SubVI by itself, e.g. like this:
So now, to get things organized, I open up the new SubVI and start renaming all the controls and indicators and repositioning their respective connectors to my heart's desire. This can get a little tricky as LabVIEW generally chooses quite ambiguous names for the connected FP elements, as can be seen in the picture above. So what I do now is open the caller of the SubVI and the SubVI side by side to identify the in-/outgoing wires with their respective names and connectors and modify them to get everything straight.
My idea therefore is to insert additional shortcut menu entries for renaming and swapping position of SubVI connectors, just like "Create >" or "Replace >" (see picture below)
The renaming could probably be done via QD - type the new name for the connected control/indicator in the QD text field, press the desired shortcut - done.
The swapping could possibly be easier to get implemented using the functionality the connector block of a VI (and several function nodes) features natively - CTRL+mouse click activates swap mode.
Glad to hear your opinions on this.
Falk
Berlin/Germany
