It is possible to restart a real time target from the Project tree in LabVIEW. However, there is no indication of the real time status. The only way to know if the target has booted is to go in MAX and look at the bottom of the window to check the status and wait for the label "connected".
It would really convenient to see "Initializing, Booting or connected" in the LabVIEW project tree.
Best regards
