| User | Kudos |
| 2 | |
| 2 | |
| 2 | |
| 2 | |
| 2 |
The second element in the ROI cluster is an array of Contours yet many sub vis will only act on the first contour in the array. Both the required contour descriptors(line and annulus) are available in the example image, but since the first element is a line, the circular edge find - which wants the annulus - throws an error.
All it would take would be a simple index and logical test to fix this issue.
