2 | |
2 | |
2 | |
2 | |
1 |
Oftentimes, rearranging or reordering a Bundle by Name or Unbundle by Name for clusters can yield fewer wire crossings. For instance, below, wire crossings can be eliminated by moving "Timestamp" to the bottom of the Unbundle and "Value" second to bottom on the Bundle:
The current process of moving one of these elements:
This can be laborious. Instead, I would like a way to quickly reorder the elements. I have a few ideas how this can be accomplished:
Just throwing out some ideas, I'm not stuck on any one. So, the idea you are voting for: Provide a User Interface for quickly rearranging elements on a Bundle or Unbundle by Name.
Re-opening because LabVIEW NXG has been discontinued.
