6 | |
2 | |
2 | |
1 | |
1 |
I have had to jump through hoops to create a .net process or use runas to get portions of code to run
when the end used does NOT have admin privileges.
Add Option under VI Properties >> Execution to allow setting the VI to run as admin or another user.
