5 | |
2 | |
2 | |
1 | |
1 |
I would like to remove all broken wires that are currently visible, and not ones hidden in other cases.
I want to be able to select a case, review the broken wires, and mass delete (if applicable). Then select the next case for review.
I never use ctrl-B when working on a large application. I want to review all broken wires before deleting.. but I hate trying to double or triple-click each wire.
Something similar to this post: broken wires ...which notes that it can be accomplished with Quick Drop scripting...
