Yamaeda
Remove unconnected on Index array
Status: New
Not too long ago i learned of the excellent Quickdrop command "Remove Unconnected" (ctrl+shift+r) on Build array and (un)bundle.
However it doesn't work with Index array and i wish it did. 🙂
That's all!
Ctrl+space -> ctrl+shift+r ->
Suggestion, it should work in this case also!
Qestit Systems
Certified-LabVIEW-Developer
1 Comment
UliB
Active Participant
I assume you want ctrl+shift+r only to look for and remove unconnected outputs or inputs too?
What should happen if there are connected inputs with unconnected outputs?
I think you are aware that the indexes for the array elements change when removing unconnected outputs and you get other results by removing these outputs, but is this true for other users?
