6 | |
5 | |
3 | |
2 | |
2 |
Capability to fast remove wire: double click right mouse button on wire you want to remove
Pointer on wire:
....just fast right double click and:
... wire is removed.
Simple and fast way to remove wire!
Nowadays you have to remove wire that way:
...or select wire with mouse and press del
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
