The command "Align Items (Ctrl+Shift+A)", under menu "Edit", should be renamed to "Repeat Align Items (Ctrl+Shift+A)" or "Repeat Last Align Items (Ctrl+Shift+A)", since it does that actually.
It will be nice have all align options in the Context menu (also called Popup menu) and the Edit menu.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
