PJM_Labview
Render tab character in string control
Status: New
In most software a tab character (/t) is "visually equivalent" to several space characters (see tab list below in notepad).
Unfortunately in LabVIEW, a tab character is visually equivalent (in normal display mode) to 1 space character. I am proposing that this should be change to be n space character.
vipm.io | jki.net
13 Comments
crossrulz
Knight of NI
PalleM, you could just use the Search and Replace String function.  There is a boolean for Replace All on the top that you need to set to TRUE.  Wire the tab constant into the search string.  For the replace string, you can use Initialize Array with a Space Constant going into the value and your Number of Spaces into the size.  Use a Concatinate String directly on the array (1 input on the concatination) and the result goes into the replace string of the Search and Replace String.
PalleM
pauldavey
Active Participant
I would love this in Free Labels as well so when I copy/paste text code (C/JS etc) it looks so much better with nice indentation.
