| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
I didn't find a post on this but i could be mistaken. It would be nice if there were a selection on the Replace Array Subset to Insert data into an index that may not be initialized. The work around is simple therefore the functionality should be easy to add. I know most will argue that this is a waist of development time but it was worth throwing the idea out there.
