4 | |
4 | |
3 | |
3 | |
3 |
This is driving me NUTS!
When I go to add a table to one of my reports, the column width is specified as a double. Can you please change this to an array of doubles so that I can have various column widths in my report? Forcing everything into equal sized columns makes the table look nasty if some of the data is wider than the rest.
It should be a simple change. I was able to fix it in 8.2, but I can't figure out how to change it in 2010, so I am leaving this up to you guys.
Or at least get rid of all the lockdowns on the report toolkit and allow us to change it ourselves.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
