6 | |
5 | |
3 | |
2 | |
2 |
It would be nice to be able to resize or move a free label while editing it. This idea revolves around a couple of situations that can occur when typing up long free labels.
Situation 1
If I type up a long free label inside of a structure, then I can't resize or move the free label while I'm typing in it. If it becomes too long and extends outside of the structure I'm typing in (loop, event, or case structure), then it automatically expands the structure no matter what I do next.
As soon as I click out of this free label or try to resize it, it will resize the While loop. Usually, this isn't my intention. I usually want to shorten the width and increase the height (to make it multiple lines), or move it somewhere else. Currently I have to finish typing, resize or move the free label, and then manually resize the structure to its previous size. If instead I can resize or move the free label as I type, then I don't have to manually resize the structure to its original size; I can just fit the free label where I need to in the first place.
This same behavior occurs if I try to move the free label while typing in it; the structure resizes, even though I'm moving the label outside of it or somewhere else.
Then as soon as I finish typing...
Situation 2
If I type up a long free label and the single line runs to the right of the block diagram, then I can't see what I am typing.
At this point, it would be nice to resize or move the free label. Instead, I have to resize my block diagram window, or click out of typing, move the free label, and double-click to continue typing.
Thanks for listening!
