8 | |
6 | |
4 | |
3 | |
2 |
deI would love to change the size of the view window only with the scroll mouse, specially with large programs, both in block diagram and front panel. In the block diagram for better control of the code and in the front panel for more quickly structure and design.
before:
after:
Best regards.
