Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/A-floating-tip-strip-showing-the-panel-dimensions-duri...
When we are resizing the window if it shows the size means it will easy to make User interface as shown
Seems a duplicate of this one...
