Simon_Holman
Resolve Load Conflicts Improvements
Status: New
When you move files around in the directroy structure (not renamed), you get prompted with this Resolve Load Conflicts message box.
For every VI file used something that has moved you must choose if you want to:
a) load with the file found in the new location.
b) load the file that can no longer be found.
I proposed having a way to automatically load the newly located file with the alternative cannot be found
OR
having a "Resolve All Conflicts" button for this case.
Simon Holman
Software Engineer
Certified LabVIEW Developer
Certified TestStand Developer
measX GmbH & Co. KG.
http://www.measx.com
12 Comments
Peter_Prinzen
and, please, make the dialog re-sizeable and keep last window size... When I have to go through 10+ dialogs, I will need always the same size of this dialog to be able to read complete path of vi's
Peter
Jamal79
HI. I have similar problem. When you are using repositories or,when you have to share VI's with your colleagues/clients. Every time you have to change location off all source files. My suggestion is, to create one more button, "Load all with Selected". That will be helpful to many users.
