6 | |
2 | |
2 | |
1 | |
1 |
When a diagram grows during the development process it's a normal act to select a part of the diagram and call the function "create SubVI".
Doing it in the opposite way (LV 2009) is very time consuming: open SubVI, go to diagram, select the code, copy, going to the main VI, removing the original SubVI, increasing the space, paste the code, re-wiring everything
=> what I really would like to see is a simple function that replaces a selected SubVI by its diagram code.
