One of the frustrating (and mystifying) things about Labview is that it doesn't seem to know what libraries it needs to compile an installer. I have to try and guess what libraries I am accessing and if I don't realise that one of the sub vis I used has used a function from the Math Kernel Library then I have to recompile the whole thing and do another test install. Depending on the size of the project and the machines that you are using, this can take a considerable chunk of time (on my machine that can be half an hour or more). It also selects a set of "standard" libraries to install, many of which I'm not using but I must take a guess as to which I don't need. Again, I won't know if a sub vi is accessing one of them until I actually try installing it.
Wouldn't it be great if Labview could look at it's own vi hierarchy and automatically include the libraries it accesses when you do a build - or at least tell you what you need like most other languages do. (Is there any others that don't?)
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
