13 | |
11 | |
3 | |
3 | |
3 |
VI snippets are useful but often hard to deal with. Sometimes you can drag one directly from a website into LabVIEW and have it just work. Other times you have to download it, open File Explorer to it and drag the file into LabVIEW.
Many times dragging directly from a website doesn't work and results in a comment with a link to the VI snippet. Instead LabVIEW should try to go to the link, download it and insert it as a VI snippet. There are some cases when this will not work (for example the user needs to sign into the website) but LabVIEW should at least try the link. It is possible a link will be provided to LabVIEW that is not a VI snippet in which case LabVIEW should recognize that and just treat it as a normal link.
I'm not sure but there may be cases when a PNG image is dragged or pasted onto the block diagram. Is there a possibility for LabVIEW to check if it is a VI snippet and treat it as such?
