11 | |
7 | |
3 | |
2 | |
2 |
If you have a missing VI, you can select "replace with" and you'll be brought to a file dialog so you can point the IDE to the file.
I'd like the same functionality with regular files. Currently the "Replace with..." menu option doesn't appear
