I am not sure how many feel this way but I sometimes feel there are too many mouse clicks to do what I want to do in LabVIEW. One of them is the ability to create references, property nodes etc. For a given control or an indicator.
At the moment you can make copy of any control/indicator simply by dragging it (using mouse left button) while holding the Ctrl button down. If I want to create a reference, I have to right click on the control/indicator > Create > then choose "Reference".
Instead, I propose that simply dragging the control/indicator using the Right mouse button will bring up the following menu.
I understand this may not be ideal for Mac users, but I am sure an alternate method can be devised.
