2 | |
2 | |
2 | |
2 | |
1 |
I'm very often in this situation:
At some point I realize that I have to change somehow my output indicator, say adding an array dimension, changing an element type, adding a cluster element, whatever.
Well, if I could just right click and choose "Adapt Indicator to wire"....
My current best general workaround is the following:
If the indicator I wanted to modify was, additionally, Hidden, there are a couple of steps more of Show/Hide... And if instead I invested in cosmetics of the indicator, I have to redo that again from scratch...
